hi all, i`m needing to reduce my escort steering tie rods about 15mm... anyone know who does shorter tie rods or adjustable tie rods...OR any other
way i might sort the problem out
cheers davy
Cut them down and recut the thread?
cut them down thread to m10 and use rose joints
10mm dia is not a good idea. No production car has steering tie rods of less than 12.5 mm dia. Thinking it of as tie bar is misleading in design terms the failure mode for a steering track rod is buckling under compression, for stress analysis purposes it fits Euler's model of a slim strut with pinned ends.
You can't do that on Ford M14x2 tie rods as the thread form is rolled into the tie rod which is 1/2" (12.7mm) dia bar stock.
