What options are there for tiger Avon master cylinder?
Not using a bias box
Cheers in advance
Easy way out and works ok is the std Sierra. A little more difficult is the old mk.1 Fiesta version or similar(maybe fiat) that has a smaller piston
and gives a better feel.
Search my threads and youll find all the info you need.
Stick with standard Sierra if you don't want bias bar.
It's cheap and easy and good. Spend you money on good discs and pads and m16 calipers. Also don't waste money or rear discs they are not
worth the hassle unless your going 13" rims them your build new uprights and wishbones so do it while in there.
