Good day fellow enthusiasts ! originally I set out to run a Cortina Mk1 rear axle,but now we have the arches etc in place it is woefully narrow...as the axle had been rebuilt the drums and backplates are all refurbed..my question is will the Cortina brakes bolt up to a Mk1 Capri axle????
Originally posted by cb500t
Good day fellow enthusiasts ! originally I set out to run a Cortina Mk1 rear axle,but now we have the arches etc in place it is woefully narrow...as the axle had been rebuilt the drums and backplbecates are all refurbed..my question is will the Cortina brakes bolt up to a Mk1 Capri axle????
Its 50" wide as opposed to the Mk2/3 which I assume are 52"
I fitted a Mk 3 Capri axle; it measures 52" between the drum backplates. And I fitted the wider rear wings.
[Edited on 4/11/15 by Dick Axtell]
The question still remains though....do Cortina brakes bolt to a M1 Capri axle?
I thank you sir.....
