Live axle..brackets for 4 bars
cb500t - 6/11/15 at 03:05 PM
A while ago I converted a Cortina axle to 4 link with off the shelf mounting brackets that simply welded ( in a semi circle ) to the axle...looked all over to find another pair without success, can anyone point me in the direction of a supplier ? TIA
Myke 2463 - 6/11/15 at 03:26 PM
Try MK Engineering.
Martin Keenan: Telephone numbers: Home: 01709 815740 Mobile:07956397404
E-Mail: martin@keenan7060.freeserve.co.uk
Address: 2, Addison Road, Maltby, Rotherham, South Yorkshire, S66 8DG
owelly - 6/11/15 at 04:53 PM
I made my own...thus:
[URL=http://s56.photobucket.com/user/moshty/media/LSRalfa/atlas3.jpg.html][ /URL]
owelly - 6/11/15 at 04:55 PM
Ebay?
PAIR GP4 ATLAS AXLE DIAMOND BRACKETS - FORD ESCORT MK1 / MK2 WORKS RALLY RACE
Oldaker - 6/11/15 at 05:00 PM
Cheaper from RallyDesign.co.uk
owelly - 6/11/15 at 05:02 PM
http://www.rallydesign.co.uk/product_info.php?products_id=4304
blakep82 - 7/11/15 at 11:28 AM
I think both of those only really work if you've got an axle with gp4 spigot ends on the axle owelly, they won't fit over the bit the brake backing plates bolt to, or brake caliper brackets, or anything really.
My choice would be a few hours spent with some steel plate, hacksaw, grinder, and marking out tools (I think I've spent too much time doing bench fitting at work) using the ones you've already got as a template
owelly - 7/11/15 at 11:44 AM
I just assumed you'd chop them in half and weld them back together.
Oldaker - 7/11/15 at 12:47 PM
That's how I fitted mine. Cut in half , weld each half to axle and weld the cut back together
