ford sierra 3.38 diff
raffo - 3/12/15 at 10:25 PM
hi I have just picked up a ford sierra 3.38 diff I have looked at most of the sierra diff numbers but can.t find my number anywhere no.s are 83 bg 4006 lc and 4 a 338 3 a 16 these are on the tag on one of the diff bolts any ideas please thanks
CosKev3 - 3/12/15 at 10:54 PM
The only real way to find out what it is is remove the rear cover and the ratio will be stamped on crownwheel
raffo - 3/12/15 at 11:19 PM
hi ok thank you I was hopeing I wouldn't have to do that cheers bob
mark chandler - 3/12/15 at 11:50 PM
You can count the turns, if you lock one output shaft then the other side is multiplied 2:1 by the planet gears so one turn of the pinion is 6:76 turns of the free side.
[Edited on 3/12/15 by mark chandler]
DRM Black7 - 4/12/15 at 08:05 AM
Check out this page.
http://www.super7thheaven.co.uk/components/sierra_rear_differential/
Doctor Derek Doctors - 4/12/15 at 09:23 AM
Its a 3.38 if the tag is correct.
raffo - 5/12/15 at 08:48 PM
thank you one and all
