What's the reccomended master cylinder setup on a tiger Avon / Haynes roadster?
Not looking for a bias setup it's initially just a road car
fwiw, On my Haynes I have just used an mx5 m/c and fixed bias valve, but replaced the reservoir with a remote one (focus) atop the bulkhead
Fiat 126 is used a lot. A few of the supplies, CBS or Rally Design do some kit aimed ones too.
Mk1 fiesta non servo master cylinder.
I put one on mine to replace the standard Sierra cylinder, loads more feel slightly more travel.
I will take a look at the fiesta one, what compensator will I need to use too?
Fiat 124 on mine. Works reallyy well with the standard Sierra Disk, drum setup.
Sorted now thanks, ordered fiat 124 one, SJ can you give me an idea as to what port goes where please
Yes, the two rearmost ones are for the front brakes - one to each caliper, and the single front port goes to the rear drums [via the pressure switch
for the brake light on mine].
Stu
Great thanks that's what I thought, is the pressure regulator a fiat part or other? Also how have you done your brake light switch?
For the brake light put a switch on the brake pedal...
I'll check my brake lights but they certainly came on really easily last time I checked.
Thanks for the heads up.
Stu
I received my master cylinder today, is there anywhere I can buy the rubber boot for the pushrod end for the fiat 124 cylinder?
