I'm going to be changing the wheels and tyres on my stylus to 13" rims and 185/60-13 tyres, the car will mainly be used on the road with 2-3
track days a year. What do you guys think will be the best tyres to go with?
At the moment I'm running the same size but in 14" shod with 888s,
Shooter
Are the r888 not meeting your needs? Too track focused?
Nankang ns2r in 120 compound are very good .
I run nankang ns2r for road and track in 120 compound and I'm very impressed with them dry grips excellent they warm up nicely after about a lap or two on track and there a good price , wet grips better than the yoko 32s I have had in the past there wearing pretty well my striker weighs 560kg so it's pretty light for a car engined car .
Been looking at an alternative to R888 and the nankang NS 2R have had some good reviews
I've been doing a search and they seem to come with XL "extra load" ratings is that an issue with a 500kg car also can you run them at
low pressures
Yes I run nankangs xl load at 16-18 psi with no problems for a road /track tyre there very good and not to bad in the wet .
I've got the 180 compound ns-2r's, they're not bad for the money.
Not as much outright grip as r888/a048r, fairly similar to a021r in the dry but don't overheat when pushed.
The sidewalls are pretty solid, however it doesn't seem to make the ride too much different at 16F-18R psi.
They haven't lasted as well as initially expected, the first 1500 miles didn't seem to make much impact on tread depth, 1500 miles further
on and they're on the wear markers, but at 45 quid a corner it's good value.
I haven't had enough wet running to give an accurate opinion, but they seemed to be reasonable for a harder compound, not as squirrely as r888
but not as good as a021r.
120 compound 54 quid
Mytyres.co.uk has been 45 quid for the 180 compound, but are now back to 60 quid a corner, their prices seem to change like the weather.
Dave
Great stuff guys, I'd seen the 120 compound for about £55 so will give them a try. I've only ever driven the car on 888 so will be nice to
try something different and save a few £
[Edited on 12/3/16 by Johneturbo]
Another vote here for the Nankang NS-2R, excellent dry grip and surprisingly good in the wet.
