Brake discs, reasonable price???
Bob C - 15/12/04 at 10:05 AM
I want some plain 10.5" rotors, <9.6mm thick - the ones with a separate alloy mounting bell (which I'll make myself).
Only price I got so far was £75 + VAT each from APracing. Ouch
Anyone know a cheaper source?
Bob C
Mr G - 15/12/04 at 11:09 AM
http://www.rallydesign.co.uk/catalog/advanced_search_result.php?keywords=rotor&osCsid=1bde99defefdb13c8b5038b8d0b5590c
Bob C - 15/12/04 at 11:30 AM
Thanks but no cigar - those are all vented & much thicker than the ~9mm I'm after
Bob
Mr G - 15/12/04 at 11:38 AM
Its ok - I gave up smoking.
The link was more a reference for a contact no. for an enquiry as to if they might have others in stock or be able to get them for you.
Hope you can find what your after
G
[Edited on 15/12/04 by Mr G]
Bob C - 15/12/04 at 02:34 PM
I'm toying with the idea of buying stock 10.5" discs for an ordinary car and machining the middle off and drilling the 6 bolt holes; why should I not do this?
OK I'm worried about introducing stress raisers & creep in the cast.
Bob
chrisf - 15/12/04 at 05:12 PM
If you are doing this, why not machine the bits from scratch?
Did you price the rotors from Wilwood?
--Chris
