Hello, I've got a 2.0 capri atlas axle on drums but I'd like a bolt on kit that allows me to run disc brakes
Ideally I'd like a set of wilwoods or similar (4 pots)
Are there any kits out there?
Many thanks
I welded two tabs on, used "heavy" Sierra calliper sand fiesta discs, 13" wheels just sneak on.
I think that's probably the route I'll have to go
Do you want or need a handbrake on the car?
ive seen the stockcar guys with f2 do this someone must make them. try mcgill motorsports
Rally design. .. xr3i discs iirc
Four pot Wilwoods on the rear??
Thanks for the replys
Yeah I'll need handbrake, it'll be for the road
The car will be fitted with a hydraulic e-brake and used for drifting so 4 pot's should make it feel more sharp
If not then I'll have to get there handbrake only caliper
