I have an idea rattling around my head that is gaining momentum but I need some data to help it escape onto the drawing board.
Does anybody have or know of where to get a drawing, 3D model or diagram with dimensions for a Mini (original not BMW) front upright/hub?
Google Search / GrabCAD are turning up blank but somebody must have this data as its such a well loved/work on/upgraded car.
Don't have any pictures except the ones in my head. The front suspension consisted of a cone shaped ali piece with a ball joint on the bottom and
a rubber disk on top (pre hydrolastic) the ball fit into the top of the hub and the hub was located on the bottom by a trailing arm-sway bar and the
drive shaft.
Pre hydrolastic there was a shock mounted to the hub and the body, this came in handy when racing a hydrolastic as the shock mounts were still there
and a Koni shock was used to control the suspension.
I have an original rear suspension but it laid horizontal with a much longer ali cone.
The cones at the front and rear could be shortened to drop the ride height.
Alan Staniforth's Terrapin used Mini uprights.
Somebody on the Terrapin board might have drawings.
There's a pretty good 2D section drawing of the front upright and hub in the Haynes workshop manual for the car.
It's not to scale, but you can scale it reasonably accurately using known dimension of components (eg. brake drum diameter).
3D CAD hadn't been invented, when the Mini was designed, so the only way you're going to get accurate dimensions in 3D is by
measuring one.
3D CAD hadn't been invented, when the Mini was designed, so the only way you're going to get accurate dimensions in 3D is by measuring one.
Originally posted by Doctor Derek Doctors
There are plenty of things accurately modelled and on GrabCAD that were designed long before 3D CAD was invented. I
. I'm very surprised that with the mini being such a widely modified and upgraded car nobody has reverse modelled the front upright or even just done a dimension schematic.
Looks like it'll have to be me! At least they are cheap to buy.
I dont know whether this is still working and/or useful:
http://minis4monkeys.co.uk/images/838.dxf
http://minis4monkeys.co.uk/images/5510.dxf
I'm restoring a Mini at the minute. I did think of measuring and cadding the upright when I was rebuilding, but it never came around that.
They shouldn't be that expensive second hand, but they require lots of cleaning
Keep in mind that the ball joint design is not the most elegant with shims to adjust the play and a grease point. I don't know if a Metro one
would straight go in.
A Metro one would fit but I vaguely remember the Metro ball joint was available in two pin sizes ,the smaller of which fitted the Mini suspension arms .Not entirely sure the Metro part gives correct steering geometry? Also be aware there are at least two variants of Mini upright , drum or disc brake .
