Hi all, this is my first post - I tried the new members section but it doesn't seem to work.
Anyway, I'm changing my worn out 4 speed manual (from a 1972 Rover p6) for an LT77 but because its a few inches longer I need a smaller brake
servo - it sits about level with the gearbox propshaft flange, hard up against the chassis at the side, back and top.
I've bought a dual circuit servo from a Micra, nice 'n' small at about 199mm diameter so it'll just about fit (a little over
¼" clearance by the gearbox) but the fluid reservoir is in the way - any reason why I can't use a couple of remote reservoirs instead of the
combined one on the cylinder?
I was thinking about motorcycle ones, specially since I just happen to have 2 from an 1100 Honda Goldwing in my stack of bits that might come in
useful one day.
noting wrong with remote reservoirs, but they will both need fluid level switches.
also quarter inch is a bit close to a gearbox, they move an alarming amount.
ps Welcome!
pull the reservior off, source two tube inserts probably 10mm and push them into the cylinder top. extend the reservoir up to where you want it with oil/fuel hose. plug your fluid switch back in. theres a few pictures on here of how its done. garyt is one of them
Cheers for the replies guys - I'm already registered and Q plated so no need to worry about fluid level switches. The old servo, from a Ford
(don't know which one though), was even closer! I would have agreed about the clearance except that there aren't any contact marks, I think
as the gearbox moved it mostly rotated around the output shaft axis rather than going from side to side /up and down? Odd really, considering how much
you can see the engine moving about when its running.
Extend the tubes - that sounds like a good idea, I'll have a search
