Hi
I've noticed my front tyres have worn strangely over the last 1000 miles. See the pics below.
The near side front is the worst, the tread blocks on the outer half of the tyre have worn unevenly and "feathered" on the inside edge. The
offside is similar but not as pronounced. Tyre pressure is 18 psi. Tyres are Toyo Proxes T1S.
Is this a result of wrong toe set up or wrong camber setting?
I did set it up myself in the past to 1 deg toe in and 1 deg negative camber (leaning in at the top), but have since raised the front and rear ride
height slightly.
What are the recommended toe/camber setting for the MAC#1 for road use?
Photos of near side front tyre taken from front.
[img]
front ns tyre 1x
[/img]
[img]
front ns tyre 3x
[/img]
Looking at your photos it strikes of incorrect toe or camber settings being front tyres. I had simialr wear issues with the rear tyres on my Passat B6 estate and was told it was a common issue (not only on VWs) by the tyre fitters. To my mind there must be an issue with the rear suspension causing the wear, but what and how would you change it. With front suspension it's usually more adjustable though.
Looks to me as if you have about 2.5 mm on inner, 3mm centre and 1mm feathering to nothing on outer?
You need slightly more camber and slightly more pressure.
Camber will even the inner/outer imbalance, and more pressure will push centre of tyre out.
Feathering on edge is normal. Unless theres signs of feathering on whole width its usually unrelated to uneven wear, and more of enthusiastic driving.
The outer edge is receiving most punishment.
[Edited on 6-6-16 by loggyboy]
My Transit tyres did that when I fitted my home-grown front hubs because I had my Ackerman numbers wrong! It tracked-up fine but once the steering was turned, the wheels were having a fight.... I got out my Poundland lazer pointers and tape measure and found my steering arms and TREs needed to be 30mm further out!
1 degree is far too much toe-in aim for 0.05 to 0.25 degrees across the axle, but on no account any tie-out.
I had some uneven wear on my fronts and found the cause was the front coilovers were way too soft. If I stood on the chassis rail, one foot either side of the car and bounced it I could see the front wheels 'bounce steering'. I checked the coilover settings and found them wound fully soft. I reset them to mid position and the problem was gone. However I then took it to Track Developments and had the full geometry re-set.
OK thanks guys, i am now going to swap the tyres front to back as the rears have loads of even tread, then re-set the toe in to 0.25 degs and 1.0 deg negative camber. Then will review the wear pattern on the "new" front tyres.
