Hi Guys,
Has anyone got, have access to a EBC 246 or similar Capri 2.8 (MK3) Front Disc?
I need some dimensions of one so I can check out fitment possibilities etc.
Many thanks,
Carl
Look at national brake component on line catalogue you should be able to get the info you need.
( National brake disc catalogue )
Hi ya,
Some dimension missing :0(
Need the diameter of the disc part that is against the wheel. The whole disc is 245mm. The disc brake surface hight is 20mm. The total hight is but
what is the diameter of the disc is 32mm so from the disc surface to wheel surface is 22mm. But I dont have the diameter of the 22mm part that has the
4 x holes and hub hole etc.
Cheers!
