For my 944 V8 conversion, I either need to use a remote servo, find a small diameter direct servo, or go unassisted.
My preference is a small diameter direct servo, does anyone know of cars which use a small diameter servo I could research for suitability.
Cheers.
Pete.
I had the same issue with my car having no room to package a decent sized servo in the engine bay and ended up using an e30 bmw pedal box which has a bell crank set up to put the servo on the n/s either in the bay or inside the car . I used a normal 11" servo from a Saab but the stud pattern on the bracket will take most servos . Cbs list a dual circuit remote unit but it's a few hundred quid
Have a look at some of the Japanese servos , I've a feeling a Micra one is pretty small?
Classic mini ones are small, the proper cooper s from the 60s was a remote
Shooter
How small does need to be?
