Hi
I have a tandem master cylinder and would like to know if I can feed it with 2 separate reservoirs.
Im looking to do it that way as I feel it would look really good.
Thanks in advance.
Dave
As far as I can tell yes but you will need two fluid level float switches so perhaps better to keep it simple.
Yes it'll work. The single res' is split into two from about halfway down anyway, so in case of one circuit leaking, it still leaves fluid in the other circuit. As BT says you'd need level switches in both res' for IVA.
Thanks guys, so I guess if I did go down that route I would need to have the switch levels wired inline?
Dave
Parallel. Otherwise both switches would need to close to pop the warning light on.
