I've got myself the sealed bearing to replace the standard Ford setup on my steering column.
But i have a lot of play in the rubber/nylon center piece that actually makes contact with the column.
Can i buy this separately? I can only see compete kits at £25
(This is the black bush that needs sanding down to fit the new sealed bearing mod)
cheers
