Can anyone help please with a recommendation for someone to refurbish a pair of half-shafts for me?
I don't think there's anything wrong with them - just want them stripped, cleaned, re-painted and reassembled.
Maybe be me missing the point, but are half-shafts not inside live axles?
Drive-shafts I've refurbished, but I can't see what would need doing to half-shafts.
I use the word half-shafts as using the term drive-shafts brings into play what I would call prop-shafts with some folk.
But yes, I mean these fella's...
It probably too far for you to drive
But I dropped off my propshaft to Autoprop in Sussex, only yesterday for a refurb and balance
It should be back with me next week, but im in no rush
http://www.autoprop-uk.co.uk/contact.php
Cheer guys.
I've been talking with a local(ish) company called Driveline Scotland Ltd. They would need to see my shafts, but reckon to budget around a £110 a
shaft to refurbish to 'as new'.
You can buy a brand new pair of driveshafts off eBay for £160 for the pair.
I don't understand refurbing or people buying 20 year old driveshafts that have done 150,000 miles .
I have some in my Hayabusa powered Mk that I use on track and they are fine
My refurb of my Sierra drive-shafts consisted of new metal cans, o-rings, grease, gaitors and clips. I re-used the actual bearings and tripods, which
were fine. The drive-shafts worked faultlessly thereafter and never leaked. I did the rufurb because the gaitors were split and the refurb kits from
the local Ford main dealer were something like £15 per drive-shaft. Removing the metail cans and peining the replacement ones in place was tricky,
but worked fine.
Personally it's not a job I'd pay someone else to do for me, but then I'm a bit tight like that really.
Originally posted by nick205
My refurb of my Sierra drive-shafts consisted of new metal cans, o-rings, grease, gaitors and clips. I re-used the actual bearings and tripods, which were fine. The drive-shafts worked faultlessly thereafter and never leaked. I did the rufurb because the gaitors were split and the refurb kits from the local Ford main dealer were something like £15 per drive-shaft. Removing the metail cans and peining the replacement ones in place was tricky, but worked fine.
Set of 2 inner kits, 2 outer kits and a pair of
shaft to transmission circlips comes in at £241.83. Add powder coat for the 2 shafts and that price rises. And that's assuming the CV joints
are fine.
Dodsons made me new driveshafts in a different length for £100 per side and made them far beefier than the originals - great job and they just needed to know the lenght and spline pattern for each end. They did take their bloody time doing it though.
There are however aftermarket gaiter kits for the shafts available for not a lot of cash... but the owners club members generally agree that they are rubbish.
Just established that OE kits were still available from the manufacturer - not cheap though.Set of 2 inner kits, 2 outer kits and a pair of shaft to transmission circlips comes in at £241.83. Add powder coat for the 2 shafts and that price rises. And that's assuming the CV joints are fine.
