Hi People.
The book states 1" for the wishbone anchors, (the round tube on the wishbones themselves, where they anchor to the body)
But I've found these on ebay Haynes Roadster Locost Front Wishbone Bushes in Poly - 10% OFF for my atom replica
build.... the diameter of "that bit" being 29mm
I'm looking to purchase my steel for this part of the build, and can't decide what I need. Any help would be appreciated.
[Edited on 22/12/16 by VinceGledhill]
i used these off the bay, and they will fit perfect the bushes you have seen
Haynes Roadster FULL SET of 22 Wishbone Bush Tubes 33.7mm dia x 35mm long.
My book states 33.7mm for the bush tubes.
The 1 inch tube is for the wishbones themselves, not the 'anchors'. The tube required for the bushes is the 33.7mm seamless. It's a bit awkward to find but is a standard size, I got about 1.5m for all the wishbones.
If you end up using 33.7x3mm welded tube make sure the seam faces the open end of the 25mm 'leg' when you weld it.
Haynes Roadster FULL SET of 22 Wishbone Bush Tubes 33.7mm dia x 35mm long.![]()
I machined mine from 1", but that's 1" nominal bore SCH 80 machined out to 25mm bore.
Thats the stuff that you would thread 1" BSP
[Edited on 22/12/16 by 907]
The one and only member of the Suttol Owners Club
Nice one Chris. That's saved me a job cutting them all. Ordered.
My book definitely says 1"
Do you have to own a Suttol to be a member or can I be an Associate member if I have parts on my car made by a Suttol owners club member?
What??????????
You want to wake up with a horses head in your bed.....
Or I suppose the equivalent - your car engine full of sand and leaking oil everywhere
