Is there enough room to swop out the LSD in the Atlas Axle on my Locos with the axle still in the car?
Is there a how-to somewhere, or is it something best left to the experts?
Thanks,
Even an expert would struggle to do it on the car. You might get lucky but usually everything will need shimming.
Yep that's an axle on the bench job to do it properly.
If you've got clearance behind the diff to get it out, it can be done on the car but it's a right pita!
Far easier on the bench...
Ian
