Hi guys, what have you used on your pedal box to hold the pushrods for the master cylinder from falling out? And can I get a rubber boot for my master cylinder from anywhere? It's Fiat UNO just to confirm.
On mine I have a pedal stop that prevents the pedal moving back beyond a certain point but other than that there is nothing else holding the pushrod in.
Thanks for reply, just wondered as I seem to recall I had seen a pic where someone made an aluminium bracket or something similar, was a bit worried about bouncing the rod out
The clevis on the pedal holds it at the pedal end and as long as the pedal can't move far enough to let the pushrod fall out I don't see how
you could have a problem.
Stu
