I have an MK Indyblade which having bought as a non runner (ignition problem) and having fixed, took out for the first time today. Now I was bracing
myself for the brakes not being great as I know they aren't servo assisted etc however I was really disappointed in these.
Current setup is 240mm front vented disks, rears 240mm solid disks. Red stuff pads all round (I suspect these are part of the problem). I tried
warming the brakes up a bit but they still were poor. I really feel I'm going to need some more front brakes.
The car will primarily be used on track days and by two of us so will get good temps. I know it's possible to get 260mm front disks, are these
the same caliper but with a different bracket to space the pad further out? On my previous trackday car (MX5) you could go up a disk size from the 1.6
to the 1.8 setup just with new brackets (and disks) and it really helped.
So I was thinking of getting a set of stock OEM equivalent Mintex front 260mm disks and going new OEM pads. Should only be about £100 all in. Can I do
this just with different caliper mounts or are different calipers needed
Pictures of current setup below.
Red Stuff pads are wank!
The rust on your discs won't be helping matters.
The brakes fitted with decent pads and all the sliders greased up nicely etc work fine and are plenty good enough for these light cars
I binned my vented discs and went solid discs. huge upgrade.
The brakes fitted with decent pads and all the sliders greased up nicely etc work fine and are plenty good enough for these light cars![]()
Get some new discs and a set of mintex 1144 pads.
I run those on mine on road and track and they're more than capable of the job. Never had any fade from them and they stop you pretty damn
quickly.
I'm also interested in this solid disc upgrade info... I thought vented would have been better?
try the discs and pads before you shell out for whole new brakes
There are thoughts that going to solid dice will improve braking as people have difficulty in getting heat into a vented setup
Due to the cars being so light meaning brakes take a long time to get to working tempreture and could be difficult keeping them there
I run vented with yellow stuf pads and find them excellent road and plenty of track time with good response from cold and I have not experianced any
fade. I also went for dot4 fluid due to better temp handspring
Might be worth you have the smallest Master cylinder bore you can get hold of as that makes a good improvement over standard sierra
New discs and mintex 1144 pads make sure the calipers are ok and sliders move freely and change the brake fluid that should sort it
XR4x4 had 260mm front discs. If you have 15" wheels you may be able to use fiat coupe or Peugeot brembo 4 pots on 300mm discs. Caprisport so kits but I think these are for the escort/Capri/cortina uprights.
Originally posted by super__dan
Still. Interested in understanding what's required to change to 260mm disks if anyone knows?
I run vented with yellow stuf pads and find them excellent road and plenty of track time with good response from cold and I have not experianced any fade.
Still on 240mm discs? In what way was it better/upgrade?
Presume that needs new calipers?
Sierra solid discs are 240mm but much thinner, ~10mm rather than 24mm so you need to be careful if you don't change the calipers too
Also the solid ones aren't all that much lighter either...
Yeah still 240 I think, and yes changed the calipers at the same time. Keeping heat in vented discs was impossible due to the weight of the car.
I don't find it impossible at all
But you do need the right pad to work well along with the correct MC to match
Thanks all for the advice. I realise you guys have more experience than me regarding these cars but I've no concern about the brakes not getting
hot enough on track as both of us are fairly committed and in my experience the mechanical advantage of bigger brakes is always worth while. I'd
rather run overly large disks and run a cooler pad.
sierra 260mm discs are a strait swap - but you need the next size up of caliper too (basically the sierra with ABS setup - but not 4x4 discs as the offsets are different)
just remember that big brakes will add more unsprung weight![]()
(I have a set of these calipers going spare that you could have for the postage cost, but they'll need a full recon)
as above, mintex pads have a really good reputation and new discs will help massively too.
I don't think anyone has mentioned your master cylinder(s) yet - what have you got ?
if you've got a MC that was really designed to use a servo (like the sierra one) then it will not be ideal without one - there are a few old threads on here regarding suitably sized MS's for non-servo setups
the right size of MC can make a night and day difference to how they feel![]()
[Edited on 15/1/2017 by mcerd1]
15" wheels should be fine, the donor cars all used 14" wheels with these 260mm brakes
those discs look right (although I never trust ebay sellers much) if you get mintex one they are: MDC438's (not that the brand will make much
difference for the discs - any half decent make will be fine)
I'm not the one to ask about master cylinders (my dax uses 2 separate ones on a balance bar as standard) - but here's one of the old
threads:
http://www.locostbuilders.co.uk/viewthread.php?tid=171237
a couple of other points you'll need to think about;
first off the bigger calipers use different pads (mintex MDB1290's should be the right ones for the 260mm type)
and second the bigger calipers have bigger pistons (59-60mm rather than 54mm) so this will have an impact on the ideal size of MC
Change of plan, going to go with the most straightforward route I.e. new standard pads and existing calliper rebuild, then in all likelihood from what
I've read a mk1 Fiesta master cylinder then see where I am and take it from there. Despite the pictures, the disks have no lips, they just need a
good clean up with some use after a year being stood.
Thanks again for all comments and advice on this thread, trying to take all the info in and decide what's best for us from there. One of my
biggest problems is I have very little time to actually work on the car, it's stored 30 miles from me and between work and home am always very
busy.
So ref MC's, I presume this 19mm one would work. Do you think the reservoir will be direct fit?
New Ford Fiesta MK1 1.1 19.05mm Piston Diam Genuine Delphi Master Brake Cylinder
If anyone knows of one going cheaper, please let me know ;-)
Mine too was hard work to bleed,I think a vacuum bleeder would be better.
I don't have much travel on my pedal,but as you describe the bite point sounds the same as mine
Vacuum bleeder kept blowing off the pipe inside the new fluid bottle. The bleed nipper position on the rear calipers seems particularly odd to me, it doesn't look like it's at the top of the piston back and it points slightly downward?
You need to unbolt the rear calipers to bleed them properly, just make sure you put something inside where the pads sit to stop the piston pushing out
as you press the pedal
I'm querying as when we bled the brakes (old fashioned 2 man method) when you let the pedal up you had to wait a good 20 - 30 seconds before pressing the pedal down again else it was like there was no fluid back in the cylinder as the pedal would go straight down and virtually no fluid would bleed out. This was odd and not very confidence inspiring.
just to ask the stupid question - does your pedal assembly allow the master cylinder to fully return ?
