Just installing my floor mounted pedalbox
What I've noticed is the left hand cylinder seems to activate before the right no matter what I set the bias bar to
My question is
Is there a correct location for the front and rear master cylinders FROM LOOKING ABOVE, DOWN.
Ie front is on the left and rear on right or vice versa
Rear is a 0.750 and front is a 0.625
Does it matter
Currently got rear on left
Do a search on here for bias bar set up or check out Rally designs website for clear instructions
As for bias bar setup there's quite a few posts on it as mentioned above.
Here
Regarding Mcyl's left/right for front/rear, it doesn't matter and is really decided by hose routings rather than convention in my
experience.
