Hi,
I have my camo Volvo petrol 2.0 turbo and the manual states 5W/30 oil but the car has done almost 100k probably hard miles and Im now thinking this
watery oil is fine when new but really a bit thin for the car now, apart from going to a 5W/40 oil is there a better grade or solution for high
mileage cars. I recently changed the oil with 5W/30 but the engine now seems nosier especially tappet noise which is now noticeable.
Stick with 5w/30 full syth unless it galloping through oil.
doesn't burn any oil and the emissions are clean for the MOT, just after changing the plugs and they were spotless so generally I think the engine is in good health, just the last oil change seemed a little bit nosier...
I'd stick with the OEM oil recommendation. 100k is not that higher mileage and as above unless it's using a lot of oil the OEM spec should be best.
Well just and update on this...
I had 5w/30 fully synthetic in but decided this was not acceptable as the noise from what seems to be the cam gear is far to loud, especially as I
have another recently purchased identical S60 which doesn't make any noise (not sure what grade its on).
So still going on the hand book for the time of year changed to a 20w/40 part synthetic and all the noise has vanished! it now runs a silently as it
should.
From this even though both oils are fully to the manufactures spec the protection of such thin oils I'd have to say is questionable and will be
steering clear of these grades from now on.
I had 5w/30 fully synthetic in but decided this was not acceptable as the noise from what seems to be the cam gear is far to loud, especially as I have another recently purchased identical S60 which doesn't make any noise (not sure what grade its on).
So still going on the hand book for the time of year changed to a 20w/40 part synthetic and all the noise has vanished! it now runs a silently as it should.
From this even though both oils are fully to the manufactures spec the protection of such thin oils I'd have to say is questionable and will be steering clear of these grades from now on.
Personally I wouldn't have gone for a part synthetic oil of any grade in a turbo car, but I only have internet based gossip to back that up.
