I have been trying to find out who makes the rear discs and from which car stumbled upon this useful web site...
http://www.brakeworld.co.uk/brakeworld/appguide/webframe.htm
You can type in the overall dimensions of the disc and it will find the part number and supplers!
Alex
^^ its ok, but for discs its got the number of studs, but it missing the PDC - and its missing the inside diameter of the bell too
so if you search for 4 stud discs in a size it will include all the Japanese 100mm P.C.D. ones - when your really looking for 108mm P.C.D. ones for a
ford / pug etc....
and without the inside diameter of the bell it wont tell you if they fit over your hubs without machining
I managed to find a PDF version of one of the motorfactors lists (2005 so slightly out of date) - it gives these extra details, send me a u2u with
an e-mail address if you want a copy.
the brake pad crossreference on your link above is actually more useful
[Edited on 10/5/2017 by mcerd1]
will send a u2u... I guess it was useful for me as I could measure what I had and it gave me 2 options which I could then check the PCD.
with our this as a starting point I was wasting hours!
Both lists taken together will give you the full picture - model and variant from the online one and detailed dims from the PDF
I'm still hunting for a better list that gives everything in one place....
