Ive started a new thread for this now I know what I want.
Been down my local factors and offered up the 3/4 19mm mk 1 fiesta master cylinder, it wont fit because the outlets foul on the steering column.
The one I need has the outlets on the right or bottom as you look along the m/c from the base.
Anyone got a 3/4 m/c on a striker and what is it ?
I recall Nova one being mentioned when i bought my striker, but i went for wilwood twin bias so not 100%
Nova ports are pointing towards the steering column but they don't look as long as the fiesta ones so a possibility.
the 1.0 lt Nova M/C has a 20.64mm bore 83 onwards
Not sure if this will be small enough.
Someone must know on here. ?
