Hi all,
I went to croft yesterday and had a great day on the track but i find my brakes really hard work. Now i just presumed that with running without a
servo they will be stiff and hard to heavy brake but then i had a go of my mates older westfield and it was alot easier to brake and im wondering if i
have missed something as i have never sat in another zero to compare.
My setup is
Ford sierra master cylinder
Ford sierra 2.0 front callipers (240mm discs)
Stainless braided flexis
Rear xr4i callipers and discs
Im going to be changing to willwoods on the front over the winter.
Could it be a cylinder problem, poor brake flaring or something else?
Thanks!
what pad materials are you using?
my bet would be the master cylinder, try smaller diameter one , most people use a Fiat punto or similar, other than that, how long is the brake pedal
leverage wise.
Originally posted by theconrodkid
my bet would be the master cylinder, try smaller diameter one........................brake pedal leverage
Its a standard gbs pedal box (above mounted) supplied by kitspares. It will depress around 2” when pressed hard. Does anyone know exactly which cylinder would be best of what car, year etc? Is there much modifications to do the mount or is just drill new holes?
Maybe worth looking at the brake pads your using before doing major mods and expense I found fitting mintex 1144 pads on my striker was a major improvement.
As others have said the Sierra 22mm mc will give a rock solid pedal that needs a really hard push. I changed mine for a 19mm Fiat MC and the brakes
are miles better.
Stu
Originally posted by SJ
As others have said the Sierra 22mm mc will give a rock solid pedal that needs a really hard push. I changed mine for a 19mm Fiat MC and the brakes are miles better.
Stu
It was from a Fiat 124 that came without a servo. You can also get a Fiesta MC that is the same diameter. I chose the Fiat one cos it was £19 from
brakes international at the time.
This is it:
[url=https://brakeparts.co.uk/shop/Fiat/124/66-85/124%20EXC%20Sport/Hydraulic%20Actuation%20-%20Master%20Cylinders%20and%20Reg%20Valves/BMC4020]Link[
/url]
I don't have any pics but can take some if you like.
Stu
Thanks stu! Yes if you wouldnt mind a couple of photos would be a great help.
I got a Suzuki 413 master cylinder for my Anglia, 3/4” non servo similar size to the mk2 escort one and reservoir fir horizontal install.
NEW SUZUKI SJ413 SJ410 SAMURAI GYPSY BRAKE MASTER CYLINDER #G208 (CODE 1427)
[Edited on 29/10/17 by Ugg10]
