Hi,
My old landy as usual has issues with the steel slave cylinder pistons corroding onto the aluminium cylinders which is kind of a design flaw as the
bottom ones face up catching water inside and never get hot enough to dry them out. It's a simple fix to clean them up but a complete pain to
have to do this regularly, things being quite heavy on it.
Two of the slaves didn't seem to be an issue but I notice they seemed to have some sort of clear grease inside the boot, is this a special
type?
The brakes use Dot 4 currently.
Any suggestions? thanks
I put some red rubber lube on the pistons before sliding them in, when the boots are on a nice bead of lube remains and keeps things nice and free.
Would you be willing to go the extra work to anodise the cylinders?
Anodising is more resistant to water caused corrossion than bare aluminium...
Also, corrosion may not be from external water, but from water absorbed by naturally hygroscopic brake fluid.
Maybe bleeding your brakes more frequently may alleviate the problem...
Castor red rubber grease.
for pistons lubrication i use ATE 03990205012 Cylinder Lubricant
https://www.amazon.co.uk/ATE-03-9902-0501-2-03990205012-
Cylinder-Lubricant/dp/B004RAVYDG
tbh I'd never heard of either of those products, they both sound superb
at last this problem seems solved
thanks
_______________________________________________________________________________________
(I'd guess its ~40 years old ! )
(its black just like some of the stuff that comes in sachets with new calipers
etc..)
When did it last have a fluid change ?
Paul G
