Hi Guys,
I dont have a key with my sierra steering column, is there a way of removing the barrel so that I can install a new one
Regards Jon
Don't know, but what about one of these...
Originally posted by johnnybizzle1986
Hi Guys,
Regards Jon
I drilled mine out but its a right pain in the ar-e
arent the seirra barrels just clamped to the column and wiring three wires or four
i got a new ignition barrel from CBS and mounted it to dashboard
Theres a little pin you need to drill out then you can release the lock barrel from the holder .
Ok
Thanks guys il give it a whirl this weekend
Regards
Forgive me but I seem to remember being told that if i screwed in the threaded end of a slide hammer then slid the weight back I only needed a
screwdriver to start and drive the car - or maybe that was several years ago
You may find any Ford key of the type Sierras used might allow you to remove the barrel ?
