I currently have the standard Sierra 260mm discs & pads fitted to my Haynes Roadster.
Recently upgraded the engine to a 2.0 Zetec so thought I should maybe upgrade the brakes as well.
Been looking at the National 8 discs and Mintex 1144 pads on the Burtons website.
http://www.burtonpower.com/discs-f-8g-ford-sierra-xr4i-rs-turbo-pbd052g.html
http://www.burtonpower.com/brake-pads-xr4-rst-sierra-abs-mk5-rs2000-mdb1236m1144.html
Just after opinions on these items / alternatives worth looking at.
Dave
I'm surprised you find the brakes lacking. Mine are standard Sierra disk / drum brakes with EBC pads and seem fine. Maybe you drive faster than me though!
I've no idea of the age pads as they were the ones that came with the donor. I presume they are just standard OEM equivalents.
You mention you run EBC pads. Which ones are you using.
I've got EBC Yellow stuff, which seem to work really well for me. What master cylinder are you running? The biggest improvement I made to my
brakes was to go for a 19mm from the standard 22mm Sierra one.
Stu
Standard Sierra MC at the moment.
What cylinder did you end up using and how much of a job was it to convert?
As always with kits and brakes, just remember your donor system was designed to stop a car twice, if not 3 times, the weight of the kit. Standard
items will be fine. Cheapest and easiest is new standard items (especially if the pads are from your donor!?!?). If you can lock up the wheels, your
brakes are fine.
I'm on Mx5 standard parts and can lock up no problem. My next step is stickier rubber!
Hi
I did have the Mintex 1144 pads but they were shockly noisy so i swapped to Ferodo DS2500, both pads brake really well I've never had brake fade
or problem stopping.
On my Haynes I'm have OBP peddle box with 2x master cylinder i cant remeber the sizes with Wilwood Midilite 4 Pot on the front and sierra disc on
the rear.
Thanks for all the feedback.
I've just gone and bought some Brembo standard discs while Eurocarparts still have their 50% off sale.
Heard good things about Ferodo DS2500's so have ordered a set of them from Burton.
Maybe keep a MC upgrade in mind for next winter.
I've got EBC 'Greenstuff' (which are widely regarded as been pants, but they came with the calipers I bought
) in the front of my
very quick BMW engined Haynes, and I'm yet to have an issue on road or track
