Does anyone have Wilwood master cylinders? I'm in the process of changing 2 separate brake fluid reservoirs to a single double chambered one. Ive
just noticed the inlet pipe going into the Wilwoods is 9 or 10 mm ID but the new reservoirs are 7mm ID. Does anyone know if i can by a new inlet for
the M/C to allow 7mm inlet pipe? Or get some inlet pipe that goes from 9mm ID to 7mm ID?
Its this part....threaded side goes into inlet on master cylinder
And here are both connected with the inlet pipe removed
[Edited on 11/5/18 by number-1]
it's these parts:
http://www.rallydesign.co.uk/product_info.php?products_id=15579
but i've got 3 spare if you want them - had to change to banjos to fit under bonnet so these are left over now
Ahhhh top man! Is there a name for them as ive searched with no luck! I need 7/16 with 7mm into the hose. Is that what you have?
I need to read before i reply!..... if you U2U me your details and the price that would be great
The connectors are apparently called 'male BSP thread to hose tail' for anyone who ever needs to order some
They arrived today mate and fit a treat so thank you very much
