Hi all. Hope you are well. As above, looking to fix the handbrake on my mk2 polo. When i got her, previous owner had replaced the fuel tank with the
wrong tank. Fitted a larger one from a later polo. As such, the mounting point had to be moved and was not refitted securely enough. The whole pulley
assembly actually came off and ended up on my drive and is still not quite right. I'm aware that the original parts are discontinued. Is anyone
aware of a set up from a different car that would fit and be easy to replace parts should need arise due to mot or general wear and tear?
The fuel tank issue has been sorted. I fitted the correct tank as the bigger one, the filler neck had been wedged in such a way that the filler hose
had been damaged and caused a leak.
Thanks for stopping by and any guidance you can give.
