Hi everyone,
Does anyone have a drawing with accurate dimensions of the offset mushroom insert please?
Or just the dimensions?
Or just the offset value, as I will be able do figure out the other dimensions.
Thank you.
The only limit to the offset will be being able to get a socket on the joint.
So the wall thickes of the mushroom plus some clearance plus the radius of the socket needed will give you your offset
Vouch,
I bought my mushroom inserts online. Can't remember from where offhand.
But I did note the dimensions, I measured the offset at 7.35mm, but the 2 varied a bit.
I can email my sketch if you need it, and could look to find where I bought it from if you need me to.
Good luck
John
Thank you very much for your replies.
I actually do not need to buy/make/fit mushroom inserts for my car, as it has been done a long time ago. I just needed the offset measurement for
another reason, and I could not measure it on my car as they are fitted, and I would not get an accurate result.
Thanks anyway for the advices and all the useful explanations.
@ johnhsmith : thank you very much for the offset measurement, and your proposal for a sketch, but someone on the Haynes Forum sent me the CAD
drawings of his inserts, so I have exactle what I needed. So don't bother making and sending a sketch, but many thanks.
Happy new year to you all
