Hello Everyone,
Looking for some help please before parting with money- running a sierra 4x4 rear end, diff, shafts, hubs but need to run 13” wheels. What Caliper
/disc combination would you recommend to fit ? Any machining isn’t an issue but just need to know where to start. The wheels are 13x7 supalights.
Cheers, Dave.
I’ve fitted a Wilwood Powerlite kit, great brakes but crap handbrake. I run 8x13 CXRs and they clear.
Cheers for that, are they direct mount on to the lugs? I don’t need the handbrake as its hydraulic only, its a hill climb mini.
https://www.dropbox.com/s/0gt2fz5ci5xipsm/IMG_20180610_180239.jpg?dl=0
I run with 13" wheels over sierra rear callipers. Had to change to springs for the handbrake though.
There are two kits for Sierra rears, mine comes with lugs as it’s the kit to replace drums, I’d check, but highly likely it’ll have a spacer or lug
bracket.
RallyDesign’s will sell them.
Thanks very much, I’ll give rally design a ring.
I found that one set of Sierra 14" would fit over my 4x4 rear and one set of 14" wouldn't!
Got 15" aftermarket alloys in the end!
