Hi Guys
Ive got a problem with my front wheel nuts undoing themselves when im driving the rears, that are EXACTLY the same type,
stud length, wheels, and nuts do not change
My car handles well, has no vibration, nor any apparent steering problems, yet has developed over the last year, more so this year! a loosening of the
wheel nuts, but only on the front
My car is garaged, and locked in, also ive put a dab of of red nail varnish on the nuts, so I know theve not been tampered with,
yet still need a couple of turns to tighten them up, even after a shortish (like me) drive
steve
Have you painted the face of the disk? As that can lead to them loosening as the paint softens with the heat, it should all be bare metal. You could also try sanding the bolt face and the wheel seat incase they are contaminated. Another thing that causes this is wheel powder coat on the seat for the bolt, again this softens so the bolts loose.
How do you tighten them? Do you use a torque wrench set to the correct setting? Are the wheels damaged around the stud holes or the center? Have the studs stretched due to over tightening? Same for the nuts? Can you change the wheels front to rear to check if the problem moves?
Are the studs fully pressed in? if they are not it might be that when you tighten them and then drive the car the forces on the wheel and the bumps help pull the studs further through.
If this is on alloys there is every chance you have the wrong type of nuts, some seat with a washer & some on a taper, if you should have the
washer type & instead have tapers the nuts will gradually "eat" into the alloy - same thing can happen with the wrong angle taper, but
less likely.
Doesn't explain why you'd only have it on the front, tho' there is far more "side force" exerted on the steering wheels, are
you absolutely certain front & rear nuts are identical?
Originally posted by russbost
If this is on alloys there is every chance you have the wrong type of nuts, some seat with a washer & some on a taper, if you should have the washer type & instead have tapers the nuts will gradually "eat" into the alloy - same thing can happen with the wrong angle taper, but less likely.
Doesn't explain why you'd only have it on the front, tho' there is far more "side force" exerted on the steering wheels, are you absolutely certain front & rear nuts are identical?
Tomorrow I will investigate more, however,
All four wheels are the same, same size same ets, same tyres,
All the studs are in and tight, infact never been out in 21 years,
All the wheel nuts that came with the wheels and all 16 are the same have been on the car for 4 years
The disk to wheel plate is bare clean metal maybe copper slipped, but not painted!
Now a thought has occurred to me, that I had a couple of tight wheel nuts when I last took the wheels off, and ive copper silpped the studs, not the
nuts, them, maybe a bit too much ? and maybe, some has gone onto the mating between nut and wheel, and allowing the nuts to slip on the wheel ?
again, tomorrow I will investigate
steve
This is my first assumption. There's different taper angles, some flat face, some with counterbore. I suspect the wrong nuts, and it is always the fronts that see it first.
