Morning All,
Looking for a couple of lower coil over brackets.
I thought that I had seen them for sale somewhere a while back......
Basically a three sided piece of thick steel box section with a 12mm hole through both sides to support the shock.
Hoping someone can help.
Thanks!
Can you not make them?
Get a short length of box section steel, cut short lengths from it then drill the Ø12mm holes across it, cut one of the faces off and you've got
your U shaped bracket.
Thanks!
Yes, have done that before.
Just seeing if available ‘off the shelf’ first.
If you don't mind paying! eBay Item
https://www.demon-tweeks.com/uk/allstar-performance-coil-over-brackets-245662/
Hope that helps...
I've got a few kicking about in my garage - let me know what dimensions you need. You've got Suffolk in your location - whereabouts are you?
I got mine from Dave at Rogue Engineering;
https://www.ebay.co.uk/usr/daveo1121
Looks like he still has them for sale, and he can do bespoke ones if you need something slightly different. He posts them out very quickly and
they're good quality.
