Hi all, Newbie here.
I have a Fireblade engined Fury that I thumped at Oulton Park last year resulting in a trashed front suspension and rack.
I've tried to get hold of Fury Sportscars with no luck, Are they still trading?
but in the meantime a few more questions if I may.
Is the rack a standard escort mk1/2
I have the old solid top rockers (one now bent) so thought this would be an opportunity to change to the newer tubular type . Can they be had from
anywhere other than Fury sportscars ?
What are people using for the uprights/links set up from bottom wishbone to rocker? I have the old scalloped out type which are not good!
Thanks in advance
Regards
Jeremy
I know AB Performance have just made jigs for Fury IRS rear wishbones and may be able to do fronts so if you can't get hold Steve at Fury.
Another option is to get hold a Jason Fourie as he works/worked with Steve and has made Fury bones for years, he posted on the Facebook page Fisher
Fury - Cars and Parts For Sale back in May.
Thanks for the info Peter, I'll get in touch with them.
Regards
Jeremy
