I need a new rack bush (the bush inside the housing, which supports the rack shaft on the passenger side) for a Sierra steering rack.
- ID 22mm
- OD 30mm
Does someone knows where to source it ?
Possibly Burtons?
Thank you.
Yes they have dome steering rack bushes but not sure it will fit since there is no measures info. Just emailed them.
If you have a Ford main dealer near you (that's been a Ford main dealer for a few years) they're sometimes worth asking. I sourced a few similar bits from my local Ford main dealer in Winchester during my MK Indy build. The parts counter guy had been there a while and happened to know their stock pretty well.
Ford parts system no longer updates older car parts when they update the system.
I went in to inquire about parts for a 1999 ST200 mondeo and most of the part numbers were unobtainable,as the new system can not read the old info
that they have decided not to convert/update.
Thank you for the advise.
In the meantime I also ordered a 22x30 bronze bush.
My intention is to keep it in position with a couple of grains
