I'm installing Wilwood 4 pot calipers on the front of my Locost (replacing the old M16 Calipers). Does anyone have any pics of how they ran the flex brake line from the chassis to the caliper? I'm having trouble trying to keep the flex line from getting tangled up with the "A" arms. Thanks, Russ
Are you aware of the trick , tightening one end of the flexi and then twisting the line to clear wishbones before tightening the other end.
Only other way , maybe using a flexi with curved pipe off the calliper.
