Handbrake cable run, and caliper position
jps - 26/4/20 at 09:28 AM
I know that i've asked about this before, but hoping I've finally got it right! How does this look for the handbrake cable run, and the subsequent position of the caliper?
Handbrake cable will run in a big 'S' - secured with a couple of loosely fitting P-clips (to allow a bit of movement) - the first where where the clamp is in the photo below and the second behind the shock in the picture below
The 'behind the shock' P-clip location shown better in the pcitire below, it'll be where the cable touches the chassis rail - just above the clamp which is currently holding the side panel on.
This leaves my calipers this way up - I expect to have to pivot them slightly to be able to bleed them - but will use the lower fitting for the flexi brake line - as in the pic below. The flexi will come to the lower chassis rail *behind* the driveshaft - i.e. towards the back of the car
[Edited on 26/4/20 by jps]
jps - 28/4/20 at 11:26 AM
Bumping this up, incase anyone can help. Had another search and just found a couple of pics which seem to show a very similar setup being used. Unfortuantely a lot of old threads either point off to defunct websites, or have broken pic links..
Thanks in advance to DarrenW
and Marc N
Who look to be using pretty much the same route as me...
rusty nuts - 28/4/20 at 11:36 AM
Have you checked clearance with the wheels on?
Mr Whippy - 28/4/20 at 11:47 AM
good call...
jps - 28/4/20 at 11:50 AM
Yes - you can see in my first pic in the OP that it clears the 14" build wheels I have on, and I will be using 15" alloys on the wheel, so I assume there will be even more clearance. But I will try the 15" to be sure.
As the handbrake cable exits the caliper the cable is already angled inboard, I think having it secured against the rear of the seat bulkhead will ensure it doesn't flex outwards at any point. The pic above from Marc N made me think I should look at securing it directly to the upright too if I can - so that the cable and upright move in unison as much as possible?
[Edited on 28/4/20 by jps]
jps - 5/5/20 at 01:06 PM
Last bump incase anyone can add their experience. It's times like these that I wish the Haynes forum was up - i am sure it's well doucmented in pictures on there!
