Evening all,
My steering column is fixed in place and I understand it has a collapsible section. However with a bit of force on the wheel it can be pushed along
the length of the column and pulled back. Clearly this isnt correct or safe, but what might I be missing to secure the column, any ideas?
Bad picture of connection to steering wheel boss:
Steering Boss Connection
Movement can be seen in this portion (max gap shown)
Steering Column Movement
Steering column for reference, I think its a Sierra?
Steering Column in Scuttle
Its a bit like this, but not as cool or innovative:
Merc F1 DAS
The inner should have a big spring on the bottom. Behind the boss there should be a spacer. It would normally be black and have a lobe for cancelling
the indicator and a notch that locates in the boss.
With these to there will be no slop.
