Is there a general ratio in which these two should appear? I just cannot find any information on setting the correct anti rollbar stiffness
Wheel rate is a factor in determining the roll stiffness of your springs. The ARB roll stiffness is added to this to arrive at total roll stiffness,
so the more wheel rate you have, the smaller the sway bar you'll need.
I highly recommend a read through this website for some very good tech articles:
Smithees Race Car Suspension Setup
Sad to say, I could once duplicate the calcs on their weight transfer spreadsheet, but the knowledge has slipped out of my head for the present.
Probably AU$295 would be well-spent in getting their guidance on roll couple, ride frequency, and roll bar specs. An AU builder who posts to the
Locost NA list has spoken well of Dale Thompson of Smithees.
Pete
thanks for the site!
So since the wheelrate has a important influence on the ride. The way to go is to get the wheelrate right for the ride and add a swaybar to get the
total roll stiffness right or Im wrong?
I guess the total roll stiffness determins how much roll the car has, but what is than the role of RC?
greetz Richard
For a flat ride it is better to have the rear spring frequency higher than that at the front, in or to put it another way ideally the front wheel
rate should be softer than the rear. To do this most road cars even fwd ones use a front anti-roll bar which allows the use of lower frequency
(softer) suspension at the front without upseting the understeer/oversteer balance or allowing excessive roll.
The realationship between spring rate and ARB stiffness has a fair bit of leeway but it has limits -- Robin Hood for example ran into trouble using a
standard Sierra ARB on the front of one model which in effect took away any indpendant movement of the front suspension.
Rear wheel rate, roll centre heights and chassis stiffness also have an effect --- use too stiff a front ARB and you can end up cornering on 3
wheels.
[Edited on 4/2/05 by britishtrident]
Originally posted by ettore bugatti
The way to go is to get the wheelrate right for the ride and add a swaybar to get the total roll stiffness right or Im wrong?
Thanks for the info. This subject is getting more clear to me
Originally posted by pbura
I think most people disregard the sway bar when determining wheel rate, though I've read in a few places that no more than half of total roll resistance should come from the bar.
Originally posted by RortyI would have thought well less than half the roll resistance should be from the ARB.
The less the better, probably, as ARBs also transfer additional load to the outside wheel, not a good thing.
