sorted out the Cortina re-con calipers, now looking at the master cylinder . Not using a servo - what do you suggest for availability to overhaul or
re-con .
Escort MKII -seals/re-con not found and new one £72 -
What to do ?
Thanks , Phil
I used an Escort one - just needed an overhaul kit to make it good.
You can get repair kits for just about any common master cylinder. The only thing that can't be fixed is rusted or worn bores - then it's uneconomic
to repair.
throw the master in the bin if it need reconing,i wouldnt re seal them,try escort 3/4 masters,similar and a lot cheaper.
Originally posted by David Jenkins
You can get repair kits for just about any common master cylinder. The only thing that can't be fixed is rusted or worn bores - then it's uneconomic to repair.
