Delrin and brake fluid
jps - 20/3/24 at 08:11 AM
As part of practicing my lathe skills I am going to turn some hose reducers (like these things from CBS: https://www.carbuilder.com/uk/black-nylon-stepped-reducer-joiner-1619mm-2522mm?gad_source=1&gclid=CjwKCAjwkuqvBhAQEiwA65XxQJozxN53oPFmuGTq0LBSXDr4 Js1xOiA2siQpLEvQz4Tw2OlHNL_2fxoCwkUQAvD_BwE).
I'm using them in the low pressure side of my braking system.
I have a sizeable stick of Delrin - so could turn them from that.
Can anyone point to whether Delrin is compatible with brake fluid, or not?
Worst case is I buy a length of brass, or steel and use that to make the reducers...
Slimy38 - 20/3/24 at 09:00 AM
Not recommended apparently;
https://www.usplastic.com/catalog/files/charts/DelrinSDS.pdf
jps - 20/3/24 at 09:22 AM
Perfect - thanks
jps - 20/3/24 at 09:32 AM
Just to update incase others find this info later.
This info indicates compatibility : https://www.spacematdb.com/spacemat/manudatasheets/Delrin%20design%20info.pdf
And some Googling has reminded me that Voucht (on here) used Delrin for reducers in the way I intended to...
Nonetheless - I think I will use brass, given it's not very expensive and it's definitely already used in brake fittings...
