Hi,
I have two English diffs, both with different prop flange sizes. The best one of the two for a BEC (3.77) has the smaller size flange and the other
(3.89) the larger flange.
Is it easy to get a prop for my BEC with the smaller flange on the end?
Pat...
Pat,
as you'll most likely be getting the prop made to measure, it shouldn't matter which diff you use - just let them know the diameter / pcd
and you should be fine
Stephen
Cheers Steve.
Didn't know if the manafacturers only made them with the large flange.
How's the car coming on?
Noticed the website is coming on!
Pat...
Originally posted by Avoneer
Cheers Steve.
Pat...
