Hi Chaps,
I've just received my shiny new shocks from GTS. Just wondering what mounting bolts to use. If anyone has fitted these can you tell me the bolt
size. I have some stainless bolts but I think I will need high tensile ones. I imagine the bolts would need to be a snug fit in the shock mounting. I
could probably go out to the garage and have a measure up but I'm laid up with a nasty virus at the moment and it's too cold outside!
I'm just about up to the task of bashing the computer keyboard!
Any help always appreciated.
Jon
I used 3" x 1/2" UNF equivalent of 8.8 (3 raised bars on the bolt head) and the appropriate nylocks
Cheers Mark.
We used M12 with appropriate Nylok's. Available in various tensile strengths indicated by numbers on the bolt head. Typically 8.8
The eye holes are 1/2"!!!
Doz supplies 1/2" machine screws, I think he called them, with a plain section for the crush tube to sit on. apparently this is a good thing.
M12 x 7cm, with stainless or zinc washers and Nylocs.
Don't forget copper assembly grease to prevent sieze later...
Stainless will cost double the price of the 12.9 black ones, even by the box. They would be nice looking though!
I haven't got these shocks, but the holes are usually 1/2" in these things, Mark Allanson would seem to concur this. 12mm if used in 1/2" holes are very likely to come loose due to movement under load.
The suspension brackets Darren makes have 1/2" holes through them.
http://www.gtscougar.freeserve.co.uk/ubracket2.pdf
The polybush crush tubes have 1/2" holes through them
http://www.cougarracing.fsnet.co.uk/polybush.pdf
So i would think logically that the shocks have 1/2" mounting holes.
0.7mm difference isnt huge, but it will put extra shock loadings on the mounts as the slack is taken up. Would recommend emailing Darren and asking
him..but i guess his answer will be 1/2" bolts are the right ones to use!
<snip>
Having bought both suspension brackets AND shock absorbers from GTS I can confirm that they are both 1/2". I used 1/2" UNF "S"
grade bolts from Namrick with washers and nyloc nuts to secure. These bolts were not expensive and well worth it for peace of mind.
I would agree that it would not be wise to use M12 bolts in a 12.7mm(1/2" ) hole and remember that you will get twice as much movement (ie 1.4mm)
as the shock absorber bush will move 0.7mm and the bracket will move 0.7mm, both in relation to the bolt.
Hope this helps,
Craig.
[Edited on 3/3/2005 by craig1410]
