Hi i have heard that it is possibel to use XJ6 suspension coilovers, is this possible? if so what models?
series 3 i think,if i can find the info anongst the junk surrounding me i'll post it on here.
you will have to bear with me as i'm sorting my files and rubbish this week
the XJ-S also has the same dampers. There are two each side at the back, making a total of four.
atb
steve
I used them and they are a bit soft but a good cheap entry with the chance of upgrading to adjustable spax at a later date for around £50 each plus a
£10 for a spring.
I think the e type was the first car to have this style of suspension and most (if not all) xj6's upto '85 have them.
They are quite big in diameter which is ok for me as I have full Sierra track at the front as well as front drive shafts so they do not look soooo
big.
