Folks,
I'm about to fix the ball joints onto the lower susp. arm, hopefully never to be removed again
Can anyone suggest a torque setting for these bolts? There are 2 at 3/8"UNC and 2 at 1/2"UNC.
rgds,
Tighten them to FT. They will be properly torqued if you do this.
I prefer the BF&I technique* for good results.
* Brute Force & Ignorance
