should the two outer mounting points of a watts linkage mount on the chassis or axle?
Thanks, Paul
I've read that it saves unsprung weight if the outers are on the axle and the bellcrank is on the chassis. I think this is how the early Ford rally cars were configured.
Doing it one way the roll centre is constant wrt ground level the other way it constant wrt the cars cg -- dosen't make much difference all
depends on how easy it to provide decent stiff mountings.
My person choice would a horizontal linkage Malllock style with the bell crank under the diff.
[Edited on 8/6/05 by britishtrident]
glad to hear somebody else is doing the watts linkage .
mine is using the chassis for the centre mount , axle for the puter points - be warned the lower tube may foul the chassis on droop /roll , so make
sure youve got clearance , ill post some pics later in the week , when i have it finished .
mine is using the chassis for the centre mount , axle for the puter points - be warned the lower tube may foul the chassis on droop /roll , so make sure youve got clearance , ill post some pics later in the week , when i have it finished .
links to pics as promised
http://homepage.ntlworld.com/mj.slater2/Phot0036.jpg
http://homepage.ntlworld.com/mj.slater2/Phot0037.jpg
http://homepage.ntlworld.com/mj.slater2/Phot0038.jpg
http://homepage.ntlworld.com/mj.slater2/Phot0039.jpg
apologies if theyre not up to scratch quality wise
I was considering a Watts linkage until I came across this http://not2fast.com/chassis/mumford.shtml Now I have too many choices!
thanks for the help and the pictures.
Paul
