Rear shocks! what length?
quattromike - 19/7/05 at 05:08 PM
I'm now at the point where I lookin at ordering some rear shocks for my build. I have the length from the centers of brackets to be 12" but i also need to add on a little don't I for rebound an that?so if i order 13" shocks it should be ok, right?
Any input welcome.
Mike.
rayward - 19/7/05 at 05:37 PM
I was advised to go 2" either side so you would need 10" closed 14" open
Ray
[Edited on 19/7/05 by rayward]
Avoneer - 19/7/05 at 06:37 PM
IIRC, when Escort live axles and trailing arms are nicely parallel, the axle sits only 1" above the bottom chassis rails so if you went 2" either way, wouldn't your axle hit the chassis on a tight corner or a big bump?
Pat..,.
Surrey Dave - 19/7/05 at 11:06 PM
I was advised to have the travel set at 33% / 66% , i.e. with 3" of travel allow for 1" up "2 down,...........
quattromike - 20/7/05 at 04:45 PM
sorry i forgot to mention i'm useing IRS , My bad .
Also i reackon that my build will be a bit heavier that the average locost would that affect the length of the shocks or just the springs?
Mike
