Has anyone got pictures of or have used inboard bike discs on thier cars?
Is it possible to use inboard brakes on the front, just cant think how that would work???
Inboard on the front is posible but not worth the effort the only RWD example I can think of is the early versions of the Lotus 72, they were later abandoned by Lotus. The saving in unsprung weight isn't great compared to conventional brakes.
didn't some alfa's have inboard brakes with their rear mounted gearboxs ?
a quick google later:
[Edited on 22/7/05 by DaveFJ]
Old rovers and some jags have inboard brakes. I cant see that the complication of designing this into a locost would yield any benefits. What are your thoughts / plans.
The formula ford running gear that I have coming my way has modified triumph herald uprights (no fitting for calipers) and I was toying with the idea of keeping them and going with inboard bike brakes either side of the modified Supra diff I will be using.
Ah Ha, never thought of google pictures
well that would save a lot of messing about!!
When the hubs arrive I will post a pic on here to check that they will fit
Mark
later 2CVs had inboard front disks. Mind you, they were FWD. If you already have a drive shaft, transferring the brakes inboard can save unsprung weight. Adding shafts to do this seems a bit futile.
one of our posters has used inboard rear brakes - was it erwe? Rings a bell...
Yes it's me.....
http://seven.dp-graphics.nl/Rear.htm
I will post some pics tomorrow.
I used Bike parts because I also used these on my first car (see avatar).
Until now I had no problems in both the trackdays I did. As you see in the pic I did use an extr air duct for cooling (this one is self made and I
wil replace it late with some Ducts)
Thanks a lot I look forward to seeing the pictures.
Anyone though about using 1 single brake for rear on the prop shaft?
Rgds
roger
[Edited on 24/7/05 by rocket]
Rgds
roger
